rwgast
Im moding a newer r80t2 based RTL-SDR dongle, this includes a TCXO, better linear regulator, freight everywhere on power lines, EMC testing, and seperating the TCXO, broadband lna4all and dongle in separate copper clad enclosures. I will then stick all the blocks inside a bigger copper clad case. Ive used a sheilded USB cable and to insert it in to the enclosures I wrapped the rubber jacket tight with 22ga about a quarter inch up and then fluxed and soldered the wire around the rubber jacket until it started melting a little bit, making sure not to ruin the inner conductors. I then painted that with liquid electric tape. The idea was to make the best gasket I could at the USB entry point. So im hoping ive basically made a Faraday cage around every block and the a bigger feraday cage around all the blocks. So hopefully no frequency will get in to the dongle except from the antenna jack!
Next the plan is to connect the SDR to this
I would be replacing the LNB with a Helical wound antenna tuned to the voyager downlink, next the part im not sure about is I would need to stick a 10ghz xband down converter in the chain.
Voyager 1 is somewhere in interstellar space out of the solar system, would a dish this big work or am I shooting at an impossible idea?
