At least for the virtual control functions if not as much for the programming. I've been able to play with the font, font size, and color to get a display I really like, that's a neat feature. I can even navigate the menu system on the scanner via the virtual interface, although it's taking a bit to figure out how that all works.
Two things I'd change if I could. First would be the ability to turn off logging, since I don't use it. Turn off logging by default that is. I know a lot of people use it, which is why it defaults on, but I'd like the option. Second, I'd like to be able to turn off the scanner using virtual control.
I'm going to play with the programming more and compare it to ARC XT to see how I like it. I
