grumpy_hermit
I noticed today that they are transmitting FD traffic simultaneously on MARCS and 154.22.
Yep they must have got that issue resolved. Shawnee Does the same thing but for different reasons.I noticed today that they are transmitting FD traffic simultaneously on MARCS and 154.22.
Yes, LFD tones and the initial call are being simulcast on MARCS and 154.220 since all 5 stations have radios that when the tones are tripped a PA announces the call throughout the station. I don't see this changing, since tones will not work on digital, that is the only way to make the call announcements heard everywhere in the stations. Central does have the capability to tone out calls also and is occasionally used if dispatch has an equipment problem. LFD does have a few pagers, but those are used very infrequently and usually by 40 hour personnel.
Mike
From what I've seen/heard so far, it seems that MARCS is a step backward and the value of this huge investment is debatable. Besides losing the capability to use tones, the radios don't allow a priority channel to be set. This means that if a radio is scanning multiple TGs, it can easily miss calls on the operator's main channel.
"S U P P O S E D L Y" Motorola and EF Johnson are in a race to find a fix for the priority issue. You can scan,.... but if the radio is on another channel it won't leave that channel until the traffic stops unless you take the Mic. off the hook. Then the radio will return to the Priority talk channel the radio is set on. As a retired cop I got to tell you THAT SUCKS!
The Tone thing is going to take some serious doing, somebody wasn't thinking when that idea was missed!
The Priority works to take the radio back to the Primary channel if the Mic is taken off the hook, but isn't over riding traffic on other channels for the primary like the VHF systems did.So it's a bug with the MARCS system, or the radios? Priority works great north of the border on MPSCS.
I KNOW that!You can't do a tone-out page with trunked systems like a regular pager, so it's not as though somebody "forgot" about it, it's just not realistically possible.
That's interesting. Well, send them up here, we know how to do that right with digital trunked in Michigan
Every radio system has dead zones. That has to do with site planning, not whether it is digital or not. The big difference is the radio now tells you when you are out of range (if that feature is enabled), where the conventional radio didn't (until no one answered you or the repeater didn't activate).
I remember when Akron went digital. The FFs were upset that the radios went out of range in some basement areas. When they tested with the old radios and new radios side by side, they had better coverage with the new digital radios, they just didn't know when they were "out of range" on the old system.
As for station alerting, paging on VHF is just one option that is selected, most often because of current investment and the fact that Mot does not make a trunked, digital Minitor pager for people to carry. There are other LAN based and wireless data based options through Zetron, Loucution, WesNet and others. Heck, Delaware County gives each firehouse a base radio set to a talk-group just for that station. They alert by adding that stations TG to the simulcast of the dispatch. No tones, no other link. It does require putting a digital control station in each house and does not solve the pager issue, although many volunteers can set their walkies to the "PA" talk-group and hear all of the runs for that station.
Options are limited when you run a comm center on control stations and not direct console connection. Since MARCS generally cannot accomodate additional direct consoles, and because of the cost, control stations are still an effective solution. Union County has been doing it since their cut mid decade.
Congrats to Lima and Allen County on their conversion. For this being their first big radio upgrade since the early 70s, job well done and still in progress.
Of course you do!That's interesting. Well, send them up here, we know how to do that right with digital trunked in Michigan
I'm by far not saying the upgrade isn't a good thing, it is, but I know some firefighters that were 20Ft from their truck in a basement that would debate that out of range thing. The problem was solved by putting repeaters on Pumpers , but that was an AFTER thought, which was my point.
Makes me wonder how MARC's intends to remedy this problem. Once the dead line to get off VHF or go narrow band has arrived, it won't make much sense to have to use both systems, that would be a SERIOUS waste of tax payer money!
Just like any repeater based system, on a trunked system it is not whether you can see the target you are trying to talk to, it is whether you can see the radio tower you need to hit to get your message repeated by the system. Lima PD had to learn this when they went from a simplex to a repeated system back in the late 90s.
After-thoughts are not system failures. They are fixes for issues that were not caught during planning, and are not unique to digital or trunked systems. OSP uses mobile extenders. Butler County has 700MHz simplex channels for fireground ops, many fire departments use simplex VHF for the very same reason.
I had a police officer get ticked off because they were 100' from another cruiser an could not talk to that car. When he finally told me the detail that they were in another county training and nowhere near the repeater, I took the opportunity to explain how talk-around/simplex mode worked. That was on a VHF system. I have had to explan "car to car" mode to trunked users as well.
Thanks for the discussion!
It might not be MARC's , but if you sell me a radio that doesn't do what I need it to, I'm coming back to you to make it right. MARC's itself may not have the responsibility for these problems but Motorola or EF Johnson should have KNOWN these issues were out there and either provided solutions or made the BUYER BEWARE!It's not an issue for MARCS to fix. Paging of local units is solely the responsibility of the user agency.
There are other options out there such as alphanumeric pagers, but they're not the responsibility of MARCS to address.
