Lincoln Fire 154.445
cubn
Marion/Johnson County, IN
I've seen on Radioreference and the CARMA profile Lincoln Fire listed as using 154.445 (110.9). Last weekend when I was there, I heard them using 154.445 (186.2). Does another user use 110.9 or is that just bad info?
gewecke
Banned
Illinois
Cubn, it could be both? Logan county S.D. uses the 110.9pl on their dispatch,but then on the other hand Lincoln PD uses the 186.2pl so you may not be wrong with either tone. I would program it in twice with both tones.
n9zas
mrradio2
Bloomington, IL
Lincoln Fire
I have always heard Lincoln Fire with the PL 186.2 Lincoln PD and Logan Sheriff also use 186.2 and Logan EMA/Paging is using 110.9
gewecke
Banned
Illinois
That's why with both tones in use,154.445 entered twice with both tones you'd be covered. It's not uncommon for one freq. to be used with multiple agencies.
n9zas
rvradioguy
110.9 pl is not used on 154.445 mhz. in Logan County. 186.2 pl is the correct tone for Lincoln Fire Dept.
