bubbablitz
- Joined
- Feb 15, 2016
- Messages
- 64
Hello everyone. The PSR-400 has no Line out or Tape out jack. If I use the headphone jack to the Mic input into an HP 5103 mini, will the volume level be varied by the knob on the scanner. I’m using the Audio Test Version 1.25 in between. I know that the volume level doesn’t vary on the Pro-2035, which has a tape out jack. Will it vary if used as described above? Analog transmissions only. Any input would be greatly appreciated. Also, would I be able to use the headphone jack on the mini 5103 as line in as opposed to the Mic in jack? Thank you in advance.
Mm
Mm
