Lines through display - XTS 5000
Hi all,
Have a weird problem with my XTS 5000 VHF radio. I have vertical lines going through the display on my radio. However, when I turn my radio after it has been turned off for a while the lines are gone and then after a few minutes they show up again. A picture is attached of what I am experiencing. Does anybody have any ideas on how to rectify this.
Giddyuptd
Here and there
Either display is going out, flex is loose or not seated proper.
If the display always had issues then could be someone put a 7/800 lcd display in it.
krokus
Southeastern Michigan
GTR8000
NY/NJ Database Guy
BEE00
Interesting. When I have had display problems, they have replaced the whole front. This was done on a pre-paid maintenance contract, so no reason to pad the parts involved.
You sure you're thinking of the XTS 5000? The display module is very easily replaceable. It sits right on top of the VOCON inside a rubber retainer, pops right off with no effort at all.
7285726C01 - MODULE, LCD (700–800 MHz)
7285726C02 - MODULE, LCD (700-800 MHz, VHF)
7285726C03 - MODULE, LCD (UHF R1, UHF R2)
krokus
Yes, I am certain. We only had 5000s, until we started getting APX radios.
GTR8000
NY/NJ Database Guy
BEE00
Very strange. The module was readily available for around $120 direct from Motorola, and it would've been much easier to simply replace the module alone than "the whole front"...whatever that even means. Oh well, ancient history I suppose.
K2NEC
None of the XTS radios should require "the whole front" to be replaced. APX is a different story. Alas, I digress.
krokus
"Front Panel" was replaced, and the radio had all new face, as there had been a couple dings in it, when submitted for repair.
