Lino Radio Room
Turbo68
East Devonport,Tasmania,Australia
This is my Radio Room and this is the equipment/antnennas that i use.
Regards Lino
RADIOS:
ALINCO-DJX2000
AOR-3000/AOR-3000A/AOR-8200M3
GRE-PSR500
ICOM-R3/ICOM-R5/ICOM-R20/ICOM-PCR1000/ICOM-PCR1500/ICOM-PCR2500
RADIO SHACK-PRO97
REAISTIC-PRO2035
UNIDEN-245/UNIDEN-396/UNIDEN-780/UNIDEN-996
YAESU-VX7R/YAESU-FT8800R/YAESU-VR500/YAESU-VR5000
ANTENNAS:
1 AKD-HAA WATSON HF ACTIVE VERTICAL 30KHZ-30MHZ
1 COMET-DS3000 DISCONE 75MHZ-1.5GHZ
1 CENTREFIRE 1/4 GROUNDPLANE 18MHZ-136MHZ
1 CENTREFIRE MULTI BAND DIPOLE 25MHZ-500MHZ
1 DIAMOND-BB6W HF LONG WIRE 2MHZ-30MHZ
1 DIAMOND-D150 DISCONE 50MHZ-1.5GHZ
1 DIAMOND-D777 VERTICAL 120MHZ-300MHZ
1 GROVE FLEX TENNA 24 FOOT WIRE 10KHZ-2.5GHZ
2 ICOM-AH7000 DISCONE 25MHZ-1.3GHZ
1 LF ENGINEERING H-800 SKYMATCH ACTICE VERTICAL 10KHZ-50MHZ
1 MFJ-1024 ACTIVE VERTICAL 50KHZ-30MHZ
1 POLAR-214A DIPOLE 118MHZ-136MHZ
1 RFI-GP3 GROUNDPLANE 118MHZ-136MHZ
1 SCANNMASTER WIDEBAND VERTICAL 500KHZ-1.8GHZ
1 WINRADIO-WR LWA-0130 LONG WIRE ANTENNA ADAPTOR
tonsoffun
Senior Moderator
Central Ontario
Awesome selection of radios Lino, nice shack and antennas!
Ron
Turbo68
Thanks there is also antennas inside the roof and i use the Diamond-CA 23RW Surge protectors on all my antennas + there is also 2 Stridsberg-MCA204M vhf/uhf multicouplers and a lot of different software for my radios and accessories.
Regards Lino.
K
kb0nly
Guest
Nice shack! How you like that NEC laptop? Never seen one like that with the half circle touch pad on it. I used to have an Acer Aspire just like that other one you have.
Turbo68
It took me a while to get use to using the NEC Laptop and recently it had a hard drive update and thats about 6 years old and paid around $3800 aussie dollars for it and it aint user friendly in comperision the ACER Laptop is easy to use.
Regards Lino
K
kb0nly
Guest
Ok, i heard others say similar things about that model laptop. Its a neat looking unit, too bad its not as good as it looks!
Great setup though!
Turbo68
I agree i didnt enjoy using it for a few years because thats when i started to get into computers but now i do run most of my radio software through the NEC versa and it took me ages to learn how to use it properley and u need to put a lot of time and effort.
Regards Lino.
scrotumola
So. Texas
Holy crap! Next to Blanton's set up, this was the next one I looked forward to seeing. Nice job.
~S~
NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
Dyer, IN
Very nice setup.
I especially like all the antennas. If I ever get out of this damn apartment I want an antenna setup like yours.
