List of DSD startup parameters/arguments
Kasmus
Europe
dsd -h
Usage:
dsd [options] Live scanner mode
dsd [options] -r <files> Read/Play saved mbe data from file(s)
dsd -h Show help
Display Options:
-e Show Frame Info and errorbars (default)
-pe Show P25 encryption sync bits
-pl Show P25 link control bits
-ps Show P25 status bits and low speed data
-pt Show P25 talkgroup info
-q Don't show Frame Info/errorbars
-s Datascope (disables other display options)
-t Show symbol timing during sync
-v <num> Frame information Verbosity
-z <num> Frame rate for datascope
Input/Output options:
-i <device> Audio input device (default is /dev/audio)
-o <device> Audio output device (default is /dev/audio)
-d <dir> Create mbe data files, use this directory
-g <num> Audio output gain (default = 0 = auto)
-n Do not send synthesized speech to audio output device
-w <file> Output synthesized speech to a .wav file
Scanner control options:
-B <num> Serial port baud rate (default=115200)
-C <device> Serial port for scanner control (default=/dev/ttyUSB0)
-R <num> Resume scan after <num> TDULC frames or any PDU or TSDU
Decoder options:
-fa Auto-detect frame type (default)
-f1 Decode only P25 Phase 1
-fd Decode only D-STAR* (no audio)
-fi Decode only NXDN48* (6.25 kHz) / IDAS*
-fn Decode only NXDN96 (12.5 kHz)
-fp Decode only ProVoice*
-fr Decode only DMR/MOTOTRBO
-fx Decode only X2-TDMA
-ma Auto-select modulation optimizations (default)
-mc Use only C4FM modulation optimizations
-mg Use only GFSK modulation optimizations
-mq Use only QPSK modulation optimizations
-u <num> Unvoiced speech quality (default=3)
-xx Expect non-inverted X2-TDMA signal
-xr Expect inverted DMR/MOTOTRBO signal
* denotes frame types that cannot be auto-detected.
Advanced decoder options:
-A <num> QPSK modulation auto detection threshold (default=26)
-S <num> Symbol buffer size for QPSK decision point tracking
(default=36)
-M <num> Min/Max buffer size for QPSK decision point tracking
(default=15)
mancow
N.E. Kansas
So, how would I select a USB sound card dongle as my input?
My setup is a BCD996T remotely monitored via Proscan. Proscan uses the regular laptop microphone input. I have the radio tapped and a separate audio line from the tap to one of the small USB type sound cards.
I would like to be able to run Proscan for regular audio and decode TRBO via the tap. While monitoring that over Teamserver.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
You need to specify to us what operating system you are using.
Linux: dsd -i <input audio device> -o <output audio device>
- ex: dsd -i /dev/audio -o /dev/audio
- ex: dsd -i /dev/dsp -o /dev/dsp
It all depends upon what audio devices you have
Windows: DSD Windows binaries [aka DSD4Win as somebody suggested it be called] are set to use the default recording and default playback devices. You can't switch via a command in DSD.
For your version of Windows, go into Control Panel --> Sound (or Control Panel --> Sound-related-choice). There will be a tab where you can set the default input device and the default output device.
In Win7 it's Control Panel --> Sound --> Playback | Recording
- highlight whichever playback | recording device you want to be default and click "Set Default"
In Windows XP it's Control Panel --> Sounds and Audio Devices --> Audio
- choose your default Sound Recording and Sound Playback devices
Mike
mescalero
hello
and 'dsd can use the serial port of the bcd996xt?
I have set the parameters-C com port 6 and the parameter is accepted and the program starts normally but if I wanted to use it as a DMR or other protocol needs to be done because the signal is not output on the screen?
I hope I explained myself .. and my suspicion 'that the com6 is over the limit accepted even if the select ..
Tips?
thanks
