i want to listen to my scanner and broadcast it to RR with tags is this even possible
i want to listen to the scanner not the online feed
Tim
Tim
I was going to ask the same question. I know UNIDEN scanners like the 996t and 996XT you can set all systems to RECORD and use the REC OUT jack. This puts a LINE OUT feed to RR and VOL Knob doesn't bother the level. The GRE I have no clue and I am ALL UNIDEN here. Someone else will have to take the ball and run with that one.What scanner do you want to use?
Mike
I use a set of USB amplified speakers.i want to listen to my scanner and broadcast it to RR with tags is this even possible
Tim
Yes you can do this.i want to listen to my scanner and broadcast it to RR with tags is this even possible
Tim
