Listen to P25 trunk frequencies individually
mdsxfire
EDBM
Uxbridge, north of the river Thames
I want to listen to the 800 frequencies on my county TRS system but not in trunking. We have 8 700 frequencies and 8 800 frequencies, I want to see how much traffic from the system is on the 800 frequencies, so I want to just have them scan conventionally and see what I hear. I have them programmed in an analog scanner and get most what sounds like the end of the repeater key up.
My question is how would I program to hear these on my G5
boatbod
Talbot Co, MD
Phase I or Phase II voice? If it's fdma voice you can probably treat it as conventional non-trunked. If it's tdma you are outta luck because there is no spec for receiving P25 P2 voice outside of a trunked system.
mdsxfire
EDBM
Phase 2 and now that u say that it makes sense cause they need the CC for the synchronization of the time slots right?
ka3aaa
middletown, pa.
If you really want to know how much traffic is on the 800 frequencies copy the system in question, lockout all the 700 mhz frequencies and upload the copied system back to the scanner and see if it will track the system if it has a 800 mhz control channel.
mdsxfire
EDBM
Unfortunately the CC is never that I have seen one of the 800 frequencies. On my old analog scanner I will get that quick data burst once one a while on them but mostly what is a quick open carrier sound
