Listen to Scannercast RR Edition Locally
charlieone
Washington
Is there a way to listen to the RadioReference edition of Scannercast on the local network?
With the regular version you're supposed to point a media player to your computer's IP and port, but I don't see a port on the RR Scannercast.
mshowman
Parker, CO
You would probably need to switch to the standard version. The RR version seems to strip out that part for simplicity.
You can still do both with the full version, and configuration is not that much different.
