Listening to construction radios in Atlanta?
I live above a big construction site and I'm curios to listen to some of their radio traffic. Such as crane operators speaking to the ground etc. I tried Close Call Only but haven't had any luck. I use a Uniden SDS100. Thanks for any help.
ecps92
Taxachusetts
FRS, GMRS, 464.5000, 464.5500, 469.5000, 469.5500 or just search 461-470
dudegt
KQ4EVS
Kennesaw, GA
They most likely are using GMRS or FRS, with some handheld enterprise Motorola radios or like @MTS2000des said they could be using a DMR or any digital trunking system for that matter.
rayvelcoro
A multitude of users use UHF allocated for low power use. Here are two common examples: 461.1125 and 461.0375.
baybum
Howard County
I get construction near me on 467mhz. Crane ops are pretty boring..."cable up, cable down, stop, left, right" etc...but fishing is part of the hobby. Good luck.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
In my experience, the General Contractor has a list of frequencies and PL codes for each project. These are typically UHF itenierent freqs and each contractor or type of contractor has a channel reserved for them on this list. Typically, each contractor may run FRS/GMRS/MURS for their internal crew comms onsite or just run on their assigned channel from the GC. However, some people tend to get upset when 5-20 crews chatting on the channel in a language they dont understand (which is why the supervisor or crew lead will carry the radio on the GC frequencies and then their FRS/GMRS/MURS radios). TT
