I've been looking around a bit and have read a lot of old info about OpenSky being "unscannable" and "uncrackable". Has any progress been made since then to either crack the protocol or make a scanner thats able to scan it?
Also, what makes it "unscannable"? Is it possible to buy an official OpenSky unit and tune it to your local LE's frequency to listen, as long as it's unencrypted?
- Cybersec
Nope and it appears there will likely never be a way to listen to OpenSky due to its proprietary nature and the fact that it isn't very popular.
Even if you bought an OpenSky capable radio and somehow managed to get software you're still SOL as you would need to know the trunking, talk group info and whatever else is required.
It gets worse, most programming is done OTA. When you first turn on your O/S radio it has to authenticate to the system as a valid subscriber. The radio then downloads the authorized talk groups. For instance, a Sgt. could log on to any O/S radio on the system and it would download the command talk groups, etc that line officers wouldn't get with their log on. The radio can be set to auto log on or to require a user password/ID.
Each radio has its own IP address and 10 digit number (XXX-XXX-XXXX). The first three are like an "area code", the second three digits are the agency code, and the last four digits are a random number.
AES encryption can be used to protect the voice and data traffic and is also extended over the back end.
I have read reports of system problems from other agencies that attempted to deploy OpenSky. I assume you're wanting to listen to Oakland County's O/S system. They have the system working very good. The coverage is great, even with a portable and the voice quality is exceptional.
Interop with the MPSCS could be improved a little, but besides that it is a great countywide system that likely will be in service for years to come.
But unfortunately, there is no known way to monitor it without having an authorized radio.
