listenning to pre defined TG in DSDPLUS ?
ronenp
Hi There
is there a way to listen to pre defined talkgroups lets say 3 or 4) in DSDPLUS ?
If so what is needed to be done ?
2) is there a way to "force DSDPLUS to listen on a specific TG from the KEYBOARD ? but not by touching the space bar because that can be done only when the TG is actice im meaning to set a TG that the DSDPLUS will wait until it is active and then it will monitor it
Thanks Forward
R
cg
Connecticut
For the first part, use the priority settings. Set everything you want to monitor below where you set your threshold.
For the second part, I don't think so. There is a workaround if it is the same TG all the time.
Example:
So if you have 50 groups on a system and only want to monitor 5, you would set the priority for those 5 at perhaps 45, leave the other 45 groups at 50 or above. This would allow audio only for those 5 groups to be heard. Set your Monitoring Threshold to 45.
The one you want to "Hold", set priority level even lower, 40.
When you want to hold, you change the Monitoring Threshold.
ALT
C
(down arrow) 9 times
Enter
(Arrow Left) until threshold is at 40
Enter
This results in only one group being heard. You need to reverse the process to return to monitoring the 5 you want. Go above 50 to hear them all.
chris
u2brent
OAMPT
KRWDPAXKRS1
Can be accomplished in the groups file..
Code:
P25,       BEE00.4A2, 7610,       69,     L/O,     468,  2020/10/03 20:43,  "MIEMSS 7R3 Med2"
P25,       BEE00.4A2, 7611,       50,    Hold,      32,  2019/09/21  0:14,  "MIEMSS 7R3 Med3"
P25,       BEE00.4A2, 7612,       50,  Normal,       0,  0000/00/00  0:00,  "MIEMSS 7R3 Med4"
P25,       BEE00.4A2, 7613,       50,  Normal,       1,  2020/10/02 13:15,  "MIEMSS 7R3 Med5"
P25,       BEE00.4A2, 7614,       50,  Normal,       0,  0000/00/00  0:00,  "MIEMSS 7R3 Med6"
P25,       BEE00.4A2, 7615,       69,     L/O,     105,  2019/10/05 14:36,  "MIEMSS 7R4 EMRC Call"
P25,       BEE00.4A2, 7616,       69,     L/O,     362,  2019/10/05 14:38,  "MIEMSS 7R4 Med1"
P25,       BEE00.4A2, 7617,       50,  Normal,       0,  0000/00/00  0:00,  "MIEMSS 7R4 Med2"
