Little help with p25 programming
JMacDonald29
So I’m trying to program Lebanon NH Fire Dept into my icom portable radio. I’m a little new to this, so please be easy! I know their frequency is 151.235 with an NAC of 800. So my question is, do I need the unit ID(hex & dec) and the talk group ID? And if I do need these as well, does anyone here have that Information available?
thanks for your help!
Isinglass311
Hi,
Since that frequency is a conventional system, non-trunked, you only need to enter 151.235 and the NAC 800.
ecps92
Taxachusetts
Question, when did Lebanon change NAC's, they were $379 not $800
Isinglass311
Change History where ??
In October Lebanon was confirmed [Scan New England] as using $379, how sure are you they are using $800 ??
go to the database and drill down to the county. At the top there are tabs. Click on the reports and downloads tab. There’s a running change history listed there.
I’m out of range of Lebanon so I only know what RR has listed for the tone. Maybe JMacdonald can verify which is correct.
ecps92
Taxachusetts
Ahh, we assume that is what he mentions, but that FD has been $379 since moving to P25 and , as mentioned, last validated as $379 back in October, never have seen them use $800 - hence asking the OP as he is trying to program a TX Radio vs Scanner, figured he had permission for the channel and knew more info than those of use who monitor only
