Little Tujunga Canyon Fire
jrholm
Big Bear
Anybody have the other tac channels being used.
So far I have
LAFD Command 860.7625
LACoFD Command 470.5125
and
LASD C-TAC-1 482.8125
Fire is currently making a run towards structures in Lopez Canyon
JayMojave
Mojave Ca
Hello JR Room:
I am in Lancaster and not hearing all the traffic. But I did hear Fox Field have Air Attach Tankers come and go, on 123.75.
But try these frequencies, 170.0 172.8125 172.6125, and search around 166 to 173.9
Jay in the Mojave
karldotcom
Burbank, CA
air to ground 167.590 heavy tankers now dropping
LAFD 18 856.7625
LAFD 2 859.9375
LAFD 13 857.4375
LAFD 9 857.2375
LAFD 3 858.9375
LAPD 42 507.0125
LACFD 4 470.5125
Mick
Western U.S.
Update: 173.625 FIRESCOPE Tertiary Crew is also in use.
From my location hearing these active frqs:
119.9750 Air to Air
135.9750 L.A. Co. Air Attack
164.1375 NIFC Tac 4
168.6000 NIFC Tac 3
168.6125 Ground units
167.95 Air to Ground Net might be where the heavy tankers are at.
LAFD 18 856.7625
LAFD 2 859.9375
LAFD 13 857.4375
LAFD 9 857.2375
LAFD 3 858.9375
LAPD 42 507.0125
LACFD 4 470.5125
119.9750 Air to Air
164.1375 NIFC Tac 4
168.6000 NIFC Tac 3
A point of clarification, Tertiary Crew is a national assignment, not a FIRESCOPE assignment as FIRESCOPE is limited to California only. If you are not hearing it used for intra crew logistics then it is probably being used as a tactical. The best way to distinguish intra crew communications from tactical is that you will hear last and even first names on intra crew and you will hear normal resource designations on tactical (Engine 22, Water Tender 31, or the name of a crew such as Dalton, Bear Divide, etc.).
Note that 168.6125 is Secondary Intra Crew. All four of the new federal itinerant frequencies are designated for Intra Crew Communications but are not restricted to this use, in fact they may be used by any federal agency without restriction. The four replaced the former two, 163.100 and 168.350. My observation is that 168.6125 is used to replace 168.350, which was the most commonly assigned itinerant frequency in the radios of federal natural resource agencies.
Uplink, thanks for the live scanner feed link. I could not find it in my bookmarks and listened to it during the Day fire in 2006. I'm confined to a hospital bed for another 4 weeks, due to a hip fracture, and am a more than a captive audience for this online scanner and KTLA. I suppose it is what you would expect a retired firefighter to be doing while laid up.
I heard a channel being called "1U," I believe on a LA County fire frequency. It was supposed to be used as a tactical on the Sesnon incident. I would suppose that could be "Blue 1" but maybe they are distinguishing the VHF from the UHF tacticals by using the "U" with the channel number. I thought the two systems were distinguished using the words "Blue" (UHF) and "White" (VHF). If that is the case what is "1U?"
karldotcom
Burbank, CA
There is a UHF and VHF "TICP" for LA County....Tactical Interoperable Communications Plan.... Every fire engine in the County should have the UHF and VHF lineup by now..... Either that or they were talking about UTAC1....but I think that is a long shot.
scannerboy02
Gov. Schwarzenegger Declares State of Emergency
Gov. Schwarzenegger Declares State of Emergency in Los Angeles and Ventura Counties Due to Wildfires
Governor Arnold Schwarzenegger today declared a state of emergency in Los Angeles and Ventura Counties due to wildfires:
"As fires burn across California, I want to commend all of the firefighters who are bravely battling these aggressive flames and the first responders who are helping their communities and fellow neighbors. Winds are causing fire conditions to change by the hour, which is why it is so important that residents in the areas surrounding these wildfires heed warnings from public safety officials to evacuate. It's critical that everyone in the warning areas continue to be prepared-know what you're going to take and be ready to move very quickly if the evacuation order comes in your area. The state is coordinating with federal and local officials to ensure that firefighters have the resources they need, but with such a serious situation on our hands, we need residents to take every precaution to remain safe during this dangerous and difficult time."
The Governor's Office of Emergency Services has activated the State Operations Center at its Sacramento headquarters. For more information, including evacuation centers and wildfire statistics, go to www.oes.ca.gov <
http://www.oes.ca.gov/> or www.calfire.ca.gov <http://www.calfire.ca.gov/>.
Full text of emergency proclamation:
A PROCLAMATION
BY THE GOVERNOR OF THE STATE OF CALIFORNIA
WHEREAS on and after October 12, 2008, wildfires broke out in Los Angeles and Ventura Counties and these wildfires continue to spread; and
WHEREAS the wildfires are being driven by high winds, and these conditions are expected to continue; and
WHEREAS several thousand acres have already burned with minimal containment, and more acres are threatened; and
WHEREAS one death has been confirmed as a result of these wildfires and others have been injured; and
WHEREAS numerous homes, businesses and other structures have burned, and many more structures are threatened; and
WHEREAS mandatory evacuations are in place resulting in thousands of residents being evacuated and seeking emergency shelter; and
WHEREAS several key local highways and roads have been closed as a result of these wildfires; and
WHEREAS the smoke from the wildfires is adversely impacting the public health in the area; and
WHEREAS on October 12, 2008, my Office of Emergency Services requested and the Federal Emergency Management Agency granted a Fire Management Assistance Grant to ensure that adequate financial resources are available to rapidly attack the fire and reimburse critical emergency response costs; and
WHEREAS on October 13, 2008, the County of Los Angeles issued a local proclamation of emergency, requesting that I issue a state proclamation of emergency; and
WHEREAS the circumstances of these wildfires, by reason of their magnitude, are or are likely to be beyond the control of the services, personnel, equipment and facilities of any single county, city and county, or city and require the combined forces of a mutual aid region or regions to combat; and
WHEREAS under the provisions of section 8558(b) of the California Government Code, I find that, because of the wildfires, conditions of extreme peril to the safety of persons and property exist in the counties of Los Angeles and Ventura.
NOW, THEREFORE, I, ARNOLD SCHWARZENEGGER, Governor of the State of California, in accordance with the authority vested in me by the State Constitution and the California Emergency Services Act, and in particular, section 8625 of the California Government Code, HEREBY PROCLAIM A STATE OF EMERGENCY to exist within the counties of Los Angeles and Ventura.
IT IS HEREBY ORDERED that all agencies of the state government utilize and employ state personnel, equipment and facilities for the performance of any and all activities consistent with the direction of my Office of Emergency Services (OES) and the State Emergency Plan, and that OES provide local government assistance under the authority of the California Disaster Assistance Act.
I FURTHER DIRECT that as soon as hereafter possible, this proclamation be filed in the Office of the Secretary of State and that widespread publicity and notice be given of this proclamation.
IN WITNESS WHEREOF I have hereunto set my hand and caused the Great Seal of the State of California to be affixed this 13th Day of October 2008.
______________________________
Governor of California
ATTEST:
_______________________________
DEBRA BOWEN
Secretary of State
