11/08 ~At 23:38 Littleton Firefighters were alerted to multiple reports of a house fire in the 7200 block of South Costilla Street. A glow and column was visible from several blocks away. First due Ladder & Medic 16 found a fully involved attached two car garage and pulled an 1 3/4 for fire attack. Engine 11 arrived shortly after and forward laid several hundred feet of LDH supply. A back up line was pulled to the bravo side for exposure protection, and a third line to the interior where PPA was in place. A 360 revealed a walk-out basement with fire conditions only present in the garage. The fire was knocked down within 5 minutes, all searches proved negative with no extension into the living space. The occupants safely evacuated prior to the arrival of fire crews. All units were held for over an hour conducting overhaul, an investigator was called to the scene.
Companies On The Ticket: BC1, SAM10, L16, E11, S12, E13, E15 & M16
Working Fire Dispatch: M11, BUR13 & Rural Metro Ambulance
http://5280fire.com/?p=21765
