Found the FCC freqs on rr for live by loews.
Cant tell what type of system and talk groups if any.
FCC Callsign WRDN546 (Live By Loews - Arlington)
FCC Callsign WRDN546 (Live By Loews - Arlington)www.radioreference.com
Look at the emission codes:
Those indicate that they'll be using DMR. It's not licensed as a trunked system, but DMR supports using talkgroups even on frequencies used in a conventional mode.
Which scanner are you trying to program? There is not a system in the database that includes this license. The license was issued (or modified to add the Arlington location) this past January. Somebody will need to monitor it, either with a scanner or one of the SDR dongles, to find what talkgroups are in use, and determine their individual usage.
Since these are DMR frequencies, create a One Frequency Trunked system in Sentinel for it.I have the DMR upgrade however if I am adding in a new Favorite I am curious to know if I should program as CONVENTIONAL with the 5 uhf frequencies
You can program these as individual conventional frequencies. While the scanner could still receive them, but you would not see any indication of the talkgroup.Thanks again for the updates.
So far only one talk group ID popped up but with no voice transmission.
I do see the SDS 100 scanning through each site however still no voice transmissions.
If I program it as a conventional system in a separate favorite will it decode dmr?
I have it programmed exactly as you indicated above.
Great points.You can program these as individual conventional frequencies. While the scanner could still receive them, but you would not see any indication of the talkgroup.
Hotel systems can be boring, with long breaks between conversations. I have the much larger Omni and Hyatt Regency Dallas hotels set up, and even on those, conversations can be few & far between at times.
I suspect that your particular hotel would be much busier when there was some event at AT&T stadium or over at Globe Life, or some other convention in the Arlington area.
