Live Oak TRS?
SABRAVEST
I'm having some trouble hearing converse selma live oak and jisd they will say a unit number for a call and then thats all you hear and they dont use that many of there frequencys sometimes it will be on lcn 3 and the next officer will keep up on lcn 6 just some minor problems if any one could help thanks alot
scanfan03
Houston, Texas
Is this Live Oak county? Is it an LTR or EDACs system? What scanner? Are you monitering it with a trunking scanner? I looked in the RR database and clicked on Live Oak County and it only showed one MOT 3600 BAUD system, which I don't think has a LCN order.
Sanscanman
N5WRF
Acworth, GA
Hey Austin,
What side of town are you listening from? I have noticed that Live Oaks Systems seems to be rather Low power. I have a Hard time picking up and following the control channel out here in Saint Hedwig, and I have noticed that tends to be true as well when you are down town or far north west. Also take a look at the LCN order again and make sure that you have all the channels. Also as scanfan03 pointed out it would be helpful to know what scanner your using to monitor thier system
Here is the Link to Live Oak City's TRS entry so you dont have to go click happy in the DB
http://www.radioreference.com/modules.php?name=TRSDB&sid=2345
SABRAVEST
I'm using a pro 2053 i'll reprogram it and ill let yall know how it goes thanks again.
scanfan03
Houston, Texas
Sanscanman said:
Hey Austin,
Thanks for the link, Live Oak City, should've known.
scanfan03
Houston, Texas
Also can you elaborate on your problem more. All I'm getting is that some one will key up and will be on lcn 3 then go to lcn 6. Its normal for the lcn to switch on EDACs systems. I don't get what your problem is. Maybe you aren't getting a good reception of the Control Channel.
