Live Scanner Feed
landonjensen
Area C
found this on EMTBravowest.com. Pretty good feed.
On Feed: LACOFD Dispatch, Response Channels, Tacticals, and VHF Channels. Verdugo ICIS and UHF/VHF as well.
IF YOU DO NOT HAVE TEAMSPEAK OR DO NOT HOW TO INSTALL TS, PLEASE READ THIS. IF YOU DO KNOW HOW TO INSTALL OR LISTEN TO OUR FEED, SCROLL DOWN.
Registering on a Teamspeak server is easier than you think. It begins first with the obvious step of downloading a free copy of Teamspeak Client and then installing it using the instructions provided. You may download it from http://teamspeak.org. Download the one matching your computer.
Once you have successfully installed the Teamspeak client, follow these simple steps to initially login as a guest user. You will then register with the server and select a user name.
First, Click "Connection" and then "Quick Connect". Then follow instructions below.
Next, enter Enter 70.87.174.165:8796 for the Server Address, a Nickname, but DO NOT select/enter a login name or password. Since you have not yet registered with the server this will cause a login failure. Click on Connect and you will connected to the server as a guest using the nickname that you selected. A (U) will appear next to your name to indicate Unregistered. Being Unregistered, you cannot listen as of yet.
Now that you have logged onto the server you will need to register. To do this, select Self on the top Menu then Register With Server. Enter the user name that you will use and a password. This is NOT your nickname, which may be different or the same. Once you have done this, click Register. Once you have registered with the server you will need to disconnect and setup a server profile.
Next, click on Connect. Right-Click on Server and begin setting up a server profile for faster logins. Directions on how to do that are next.
Enter INB for "Label", followed by your publicly displayed nickname, and click on bubble in Registered. Then enter the username, and password that you just registered with. We recommend that you also select Auto Reconnect in case you are disconnected from the server. Leave everything else blank. When you have finished, click on Connect. You should be connected. If a Error Message pops up, make sure everything was entered correctly. If you are still having problems, email us at ina.ca112@gmail.com.
IF YOU ALREADY HAVE TEAMSPEAK DOWNLOADED, ENTER THE FOLLOWING FOR THE SERVER ADDRESS.
70.87.174.165:8796
You also still have to register with the server. If a Error Message pops up, make sure everything was entered correctly. If you are still having problems, email us at ina.ca112@gmail.com.
