I have set up a live scanner feed covering all of Ada County Fire Departments and one for Nampa Fire Dept
ScanAmerica: Live Police, Fire, and EMS Scanners
then click on Idaho and click on the desired county.
Another feature is the feeds are archived for several days. So you hear about something that happened in the middle of the night or well you where away from your scanner now you can listen to the action.
(Some of the Ada County Ops channels you will only be able to hear dispatch and not the units depending on the location of the incident from my house. West Boise, Meridian, Boise Bench all come in pretty good)
(Most of Nampa Fire incidents you will be able to hear fine as the scanner I am using for NFD is located in Nampa)
