traperjeff
Can any one tell me what is involved in seting up a live scanner feed on the net
You might also want to look into Winamp/Icecast/Oddcast. If you want to stream text from a Uniden 246 or 396 scanner, this is the free way to do it.traperjeff said:Thanks Andy and Idle, I will get all the info together and list it also should i use a dedicated computer for this.. Thanks Jeff
traperjeff said:ok i'm trying to set up Icast withe the help of scan mass. it calls for a host name what is that . I don't want to sound stupid but I don't understand...... do i need a host site for the feed??? I have broadband cable and it says it is running at about 950kbs I have the cord and simplecast what elese do I need
thanks,
I do not have a domain. Do I need one or do I use my ip for my computer on road runner. I'm sorry I don't want to sound dumb. I am just new to the live feed thing....ve3nsv said:Host name is the public address that your stream will resolve to, for instance mine is ve3nsv.no-ip.org. If you have a domain or one of those free redirecting DNS services just put that in there.
What Icecast wants there (I assume you're talking about in icecast.xml) is localhost if winamp is running on the same computer, or the internal IP (192.x.x.x or 10.x.x.x) of the computer Winamp is running on.traperjeff said:ok i'm trying to set up Icast withe the help of scan mass. it calls for a host name what is that .
Not for the feed, no.do i need a host site for the feed?
If you want to sent text tags, I'd suggest oddcast, not simplecast, if you're running a 246 or a 396. The software on scancapecod that's used for text tags will work (if you get the 246 version - the 396 talks the same protocol), but simplecast isn't free - oddcast and metagenerator are, and metagenerator lets you key on text, not tgid or frequency, so you can have the same id (or the same frequency with a different pl) come up as a different service..I have the cord and simplecast what elese do I need
