Excellent point since the OP did not provide info on his antenna. I'm a stickler for using 50 ohm cable for a 50 ohm rated antenna, but for a Scantenna or other thing that is intended to use 75 ohm cable I would upgrade to low loss foam type RG-11.
For any other antenna rated at 50 ohms like a Discone or multiband ground plane, the antenna should provide close to a 50 ohm impedance on its design frequencies and you want to use the lowest loss 50 ohm cable you can afford. If you have a certain but known performance with RG-58 50 ohm coax and you upgrade to LMR-400, the improvement will be very predictable and you can figure it out from coax loss charts. If you go from RG-58 to RG-11 with a 50 ohm rated antenna all bets are off and some frequencies may have less loss and others could be way different than you expect.
Published coax loss is based on a matched system where the source and load are the same as the inherent impedance of the coax. When the source or load (antenna or radio) are a different impedance than the coax, then the coax loss goes beyond the published spec.
Bottom line is, if you have a 50 ohm rated antenna, use a good 50 ohm coax and your done. You never have to think about it again. Also be aware that most antennas (besides a Discone) will only have a good match on fairly narrow regions around where they are designed to work if the mfr is somewhat legit. Many scanner antennas are not much more than some coat hanger bits cobbled together and there is no real design behind them, so the 50/75 ohm coax argument may not apply.
An actual Discone like the RS, Icom, Diamond, Comet, Workman, etc, and not a Hustler or Centerfire, etc, will have a good match over the roughly 100 to 800MHz range and will provide a good match to 50 ohm coax over that range. This is really important if your going to use a preamp because many preamps will have oscillation problems if not terminated with a reasonable match over their entire operating range.
prcguy
You are assuming he is using an antenna with a 50 ohm feed point.
Some scanner antennas use a 300/75 ohm transformer at the feed point such as a " scantenna"
