Loading LATIE
tjbroussard
Mandeville, LA
Just back to forums after completing my retirement move back to Lafayette. I am now loading my LATIE and trying to figure out how to stuff it all in. Tried the auto method and exceeded the load limits of the 396.
Any ideas or suggestions?
Thank you...
loumaag
Silent Key - Aug 2014
Katy, TX
Thank you...
Um, you can't put all of LATIE in any scanner that I am aware of. At least not in any sensible way. Now stop and think, do you really want to be monitoring everything? First, you can't really follow everything happening in your area and second, you really don't want to load up stuff 100 miles away. Concentrate on setting up a system for the local area with what you really want to hear normally. Then make up an other local system that has things that you normally wouldn't listen to but might be interested in sometimes. Then set up systems for traveling to different parts of the state.
Pro_Se
If you still want to load all of LATIE, you will need to split the ID’s up into multiple systems to get around the limit of 200 IDs per system.
