TRX-2: Loading Older Firmware
Coolant113
Warren County NJ
I have been having lots of problems with my TRX-2 receiving P25 systems ever since I sent in my unit to get repaired, and they replaced it with a newer unit.
The firmware on the one that I sent them was a much older version than what is on the new model they supplied me with, which worked flawlessly on P25 systems.
I just got off of the phone with Brian from Whistler, and he supplied me a utility to run to load version 4.3 onto the scanner. However, I cannot get the computer to recognize the scanner once I put the unit into "CPU Update Mode".
Has anybody ever used this utility? If so have you faced similar problems with it?
2006walt
The Villages, FL
Sounds like you have a driver problem. Your PC is not connecting via USB to TRX-2. Hopefully someone can explain step by step how to fix the driver issue. I am trying to figure out myself.
2006walt
The Villages, FL
Coolant113, did you download the latest versions on EZ Scan from the Whistler web site?
Wackyracer
Reinstall the driver and if it is windows 8-10 make sure you do "Unsigned driver" Procedure. google it!
