Loaner USB audio card?
SignalSeeker
West Sacramento
I just switched my feed over to a thin client server and have a hum now. Anyone in the Sacramento area have a USB sound card they would want to let me try? If you have a spare and it fixes it I will buy it.
Thanks,
Justin
gmclam
Fair Oaks, CA
The hum is typically caused when you use the headphone output of a GRE scanner. There is no ground on that connector so you get a hum. If using a GRE scanner, use the ground from the antenna connector (or external power) for the audio ground and the hum will go away.
SignalSeeker
West Sacramento
Got it taken care of now. I was using a barrel plug splitter, on side to power the thin client with the other going to power the mobile scanner. Once I used a seperate power supply the hum was gone. At first I thought it was just a crappy onboard sound causing it.
It is a Radio Shack mobile scanner and a WYSE thin client.
Thanks,
Justin
