I'm still really new to all the scanning information out there. I'd like to listen in to my local airport, which is about a mile away from me, and I found the page in the Sticky with all the airport information listed, but I can't find anything that tells me what exactly what I will need to program my scanner "pro197" so I can listen in? If anybody could point me in the right direction I'd appreciate it.
Well, you're lucky, living only a mile from your airport, which means you'll be able to hear BOTH sides of the conversation when the control tower operator and all the different pilots talk to one another. For instance, I live about 12 miles away from my local airport and I cannot hear the tower operators. Why, because the tower works on low power. They only need to cover about a five-to-seven-miles radius around their airport. I can hear the aircraft calling in, because they're up high, but I can't hear the control tower.
So, if you have the airport information, as you say, program the CONTROL TOWER frequency into your scanner. If your local airport has more than one runway, then your airport likely has has TWO control tower frequencies -- one for each runway. Don't forget to program in the GROUND CONTROL frequency, so you can hear the planes on the ground being directed on how to taxi. If your airport is large enough to have commercial airliners, then also program CLEARANCE DELIVERY, so you can hear where those airliners are heading to. Also, try to find your local APPROACH/DEPARTURE frequency so you can listen to planes coming to and heading away from your airport.
So, just to give you an example, my local airport, Fullerton (CA) Municipal (KFUL) has one controlled runway on a frequency of 119.1. Ground Control is on 121.8. Because my airport is small enough, this frequency also serves as Clearance Delivery. When I visit Fullerton Arport I always listen to Ground Control because I'll hear the tower give the pilots instructions on how to fly to Santa Barbara, or Montgomery Field in San Diego, etc. Southern California Approach and Departure Control is on 124.65. So I can listen to pilots either en route or departing from Fullerton, should I choose.
Also, don't forget the ATIS frequency. This is an automated broadcast that gives pilots the local weather and, most importantly, the current altimeter setting, so the pilots won't come in too low or too high and crash on the runway. Since this is a continuous broadcast, I usually have the Fullerton ATIS on 125.05 locked out on my scanner.
One other thing, if your local airport doesn't have a control tower, then you'll need to program your airport's UNICOM frequency into your scanner. When an airport is UNCONTROLLED, meaning there's no tower, the pilots get on the Unicom frequency and talk to each other so they don't collide either in the air or on the ground.
So, if you have the frequencies for your local airport, then just follow the directions in your scanner's owners manaual on how to program frequencies and you're golden.
Dave
KA6TJF
