Local Philly Colleges Temple, Drexel and now UPenn now on MOTOTRBO
NUGEN
Phila, PA
I already knew Drexel and Temple were on MOTOTRBO but it seems that UPenn has switched over to it. To my knowledge Uniden or any other scanner manufacturer doesn't make a scanner to decode it. Is there a way to decode MOTOTRBO other than using a discriminator tap and digital speech decoder?
Is it possible to just buy a MOTOTRBO radio and have it programmed for those colleges? If so, does anyone know a local place in the philly area to buy it and have them program it.
NUGEN
Phila, PA
Is it possible to pickup and listen to MOTOTRBO without using DSD?
My local colleges are all now on MOTOTRBO (DMR). Can someone tell me is it possible to buy a radio from the list below and get it programmed to Temple, Drexel, and UPenn college in Philadelphia, PA?
This is the link to the colleges page, UPenn's frequencies list is old, they have switched over now.
Philadelphia County, Pennsylvania (PA) Scanner Frequencies and Radio Frequency Reference
MOTOTRBO Portable/Mobile Radios and Repeaters
(Models sold in the United States.)
Portables
XPR 6500 (display, non-GPS)
XPR 6550 (display, GPS)
XPR 6300 (non-display, non-GPS)
XPR 6350 (non-display, GPS)
SL 7550 (display)
XPR 7550 (display)
XPR 7350 (non-display)
XPR 6580 (display)
XPR 6380 (non-display)
XPR 6100 (non-display)
XPR 3500 (display)
XPR 3300 (non-display)
Mobiles
XPR 4500 (full display, non-GPS)
XPR 4550 (full display, GPS)
XPR 4300 (numeric display, non-GPS)
XPR 4350 (numeric display, GPS)
XPR 4380 (full display, GPS)
XPR 5350 (numeric display, GPS)
XPR 5550 (LCD display, GPS)
ff-medic
Banned
The Appalachians - Next to the tent and campfire.
Go to Google. Search radioreference.com - mototrbo - decoding.
There is a search function in the top right hand corner......it works also.
There is a ton of threads on this site, already on the subject.
FF - Medic !!!
mikewazowski
Staff member
Central Ontario
Yes, you can purchase any one of those radios along with a programming cable and software and you should be all set unless they've enabled Privacy or RAS on the system.
You'll need to use a program like DMRDecode to figure out the correct settings for the system.
phillydjdan
I have an XPR4550 UHF and have several of those agencies in my radio. It does work, but you have to know the color code, slot, and group for each frequency. I dont know them off the top of my head right now. If you get an XPR4550 I can program it for you. Im not certain what other mobiles will work with my cable, but I think my software covers all TRBO models. If you need a portable programmed, I cannot help you there.
