Locking all systems on a BC246T
bearcat246tscanner
Houston, Texas
Is there a way to lock ALL systems on the 9 Q-Key that are pre-programmed into the BC246T and then unlock just the ones you want?
There are so many pre-programmed in and is hard to lock all but the ones that are an interest to you.
Manually go to each system you don't want to listen to and push the L/O key.
captclint
Mountaintop, PA
I didn't think the 246 came with pre-programmed frequencies:confused: If you bought a used radio, or had someone else program it, a better solution would be to delete the systems you don not want. That way, you will have all the Quick Keys available for the systems you want.This comes from Easier to Read BC246T Scanner Manual, which you may find quite helpful :
To Delete a system, press Menu. At 'Program System' press E/Yes.
At 'Select System' scroll to the system you want to delete and press E/Yes.
Scroll to 'Delete System' and press E/Yes.
At 'Confirm Delete?' press E/Yes.
Press Scan to exit.
