Whereas freqseeker03 was indeed logged in when he posted that message, as evidenced by the "Donating Member" icon, that only means he was logged in to the forums. Forum login is seperate from the DB and rest of the web site. If you go to the Home Page (link above) look at the Upper Left just below the picture of the antenna farm and you will either see "Logged in as (Your Name)" or you will see "NOT LOGGED IN". To reach the Donations stuff, you have to be logged in on the main part of the site. The log in should be the same for both areas, but I guess it is possible to have gotten them out of sync. If that is the case, a message to the Webmaster by using the address available at the "Help" link on the Home Page would be in order.
