Long Island Mil Freqs.
gsxr4000
Hey all, I live out on the East End of Long Island. I just picked up an R/S 2055 to monitor the Mil/Air Freqs. However...I have about 200 Freqs. I have gathered from around the net, and I don't hear anything at all. And I also have an ANG Base not even 2 miles from my house...the landing "pattern" goes right over my back yard!!! So my question is....does anyone have any Freqs. that will ACTUALLY WORK???
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
What antenna are you using? If it's just the little stick that comes with the 2055, it's not going to be very easy to hear any milair. A good antenna, fed with the proper coax, is an absolute must . A Diamond discone, NilJon, ScanTenna, and others are all worth checking out.
As for your ANG base, a question or two on the NY forum, and on the forums I will mention a bit later, may bring some answers. Often ANG groups use the 138-144 Mhz range (in AM mode), but that's still a tall range of real estate to cover.
I see you posted the same question on the NY forum - you might want to watch that; cross posting is considered a no-no...
As a starting point, I would pull the ZNY ARTCC UHF frequencies from the database. I would also do a search on N2NOV and NF2G's websites for the big 3 in the area (LaGuardia, Newark, JFK) and concentrate on their UHF freqs. I don't know if they would fly in your area, but I would also consider putting some Bradley (Ct.) freqs as well.
Folks on the Maryland milair thread have noted 4 new ZNY freqs that don't seem to be listed anywhere; these are
292.15
282.65
327.6
336.075
Finally, I'd jump in on the ScanCom and ConnScan Yahoo groups - it surprises me that I've never seen much from the NY area on the well-known Milcom group at QTH.Net, but there may be some lurkers there, too.
If you do come up with a good list, I'd like to see it - in fact, I'd probably turn it into a Wiki page in a heartbeat. There just doesn't seem to be a good list of active NY freqs anywhere, apart from the DoD publications (which will be going away in less than a month....)
73s Mike
[edit] Ken, who posts frequently on the MilAirCommsChat Yahoo board, has these 3 freqs for app/dep for Bradley;
323.2
325.8
348.3
If you don't have them on your list, it might pay to add them.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
These, of course, aren't milair freqs - but thanx anyway.
Don't forget to check Airnav for additional freqs - it's as good a starting point as any.
One thing about the ARTCC listings - it's been discussed extensively both in the aircraft forum and other places, so I won't go through all of it - but the ATA100 listings that are used here are not the most accurate. For example, anything listed 'do not publish' I understand refers to old Tac freqs that hasn't been used in years, so give anything like that a pass. Stick to the listings that follow the ATA100 data; you'll be much better off.
73s Mike
gsxr4000
I couldn't find any Freqs. for Mil/Air....but "cookiend15" here on the forum did a search and found these for me.
Sorry for the double posting :(
Francis S. Gabreski ANGS (Westhampton, Long Island, New York)
121.800 Ground Control
122.950 Unicom
125.300 Tower
132.250 Approach / Departure Control
142.125 Munitions
143.425 Comm / Electronics Maintenance
162.6125 Medical Net
163.4625 Maintenance
163.4875 Fire / Crash
163.5125 Supply
163.5875 Base Operations
165.0125 Ramp Control
165.1125 Security
165.1375 Aircraft Maintenance
165.1625 Command Net
225.400 Ground Control
229.100 NORAD Air Defense Air-To-Ground
235.800 NORAD Air Defense Air-To-Ground
236.600 Tower
239.400 NORAD Air Defense Air-To-Ground
251.900 Search And Rescue Training
278.200 NORAD Air Defense Air-To-Ground
284.800 NORAD Air Defense Air-To-Ground
287.500 106 Rescue Wing Operations
288.100 Approach / Departure Control
ALL FREQUENCIES LISTED BELOW ARE
NORAD AIR DEFENSE AIR-TO-GROUND
292.400
298.800
316.200
327.200
338.400
342.100
348.800
351.600
371.000
376.200
379.000
384.000
389.200
394.800
396.800
399.000
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
122.950 Unicom
125.300 Tower
142.125 Munitions
163.5125 Supply
165.1125 Security
236.600 Tower
292.400
298.800
316.200
327.200
338.400
342.100
348.800
351.600
371.000
376.200
379.000
384.000
389.200
394.800
396.800
399.000
Interesting list; I'm willing to bet the reason you didn't find any milair freqs on the database is because you didn't know where to look - examine the bottom of
http://www.radioreference.com/modules.php?name=RR&stid=36
There are 3 ARTCCs listed here; you want the New York and Boston centers (since it seems, according to the map, that the eastern tip of LI sticks into the southernmost edge of their coverage area). For the Boston center, I'd choose the sites closest to you.
The freqs you want are between 225-400 Mhz, and there's several possibilities.
73s and good hunting...Mike
