A Windom (single conductor feed line), or an OCF dipole (two conductor/coax fed) are basically the same thing, sort of. The length of the feed line with the Windom antenna makes a lot of difference because a Windom antenna is a vertical antenna with a capacitive hat. An OCF dipole is just a dipole that has had it's feed point moved toward one end. The reason that's done, mostly, is because it changes the antenna's feed point impedance. The length of the dipole determines it's resonance, and also has harmonically related 'resonance' points at higher frequencies. A center fed dipole also has those same harmonically related 'resonance' points, the difference is in where the thing is fed and it's input impedance.
- 'Doc
