Long Range Antenna?
Your_account
.AT
Hey
i hear someone use long pipe of cooper pipes under the attic for a great signal.
some friends use citizens band radio on there car and the antenna is vertical polarized but the antenna on the attic is horizontal polarized.
So how can that work? And it is work how long should the coper pipe be?
Lower frequencies tend to bounce around a lot, so antenna polarization isn't quite as critical as it is on higher frequencies.
AM broadcast stations use vertically polarized antennas, but a horizontal wire antenna will receive them fine. Same with CB. There is likely a bit of signal loss, but probably not enough to really make a difference.
Length of copper pipe needs to be something resonate at 27MHz. two lengths of 108 inches would work to make a simple dipole. Doesn't need to be copper pipe, though. Plain old copper wire will work fine.
jackj
NW Ohio
Most HF antennas are horizontally polarized for a number of reasons. QRM (man made RF noise) is mostly vertically polarized so using a horizontal antenna will reduce the amount of noise you receive. A skip signal's polarization will be scrambled so receive antenna polarization won't make a great deal of difference. Why not go with the less noisy option. Another reason is the length of the antenna makes mounting one horizontally much easier than vertically mounting. A half-wave antenna at 27 MHz is going to be about 17 - 18 ft long.
The penalty of cross polarization is going to be between 20 to 30 db.
k9rzz
Milwaukee, WI
A vertical signal polarization isn't the point on HF (like it might be on VHF/UHF), it's the low angle to the horizon that vertically polarized HF antennas favor. You can have a very low angle of attack to the horizon with a horizontal antenna, but it has to be high off the ground. Like 60 feet or more. How high is your attic? Does it really make a difference? It makes a HUGE difference.
Angle of Radiation - What is it?
https://www.google.com/search?q=ang...IrH8AHe9oHQCw&ved=0CAgQ_AUoAQ&biw=907&bih=438
Your_account
.AT
So how can i build an Antenna for CB Radio who have the maximum Gain?
sdeeter19555
Reading, PA
Stupid question on the copper pipe, but if you were to simply screw two 108" lengths of copper pipe to the rafters (think horizontal dipole), would the wood act as an insulator? That would be a fairly easy install, two pieces of copper pipe, about six screws for anchoring, and you could solder the coax to the pipe.
I know wire can be used, but the pipe being rigid has its appeal...I have also made a dipole with two 102" whips and allowed them to droop, and that worked pretty good.
prcguy
Basically yes and the feedpoint ends of the pipes would be less sensitive to insulator properties than the ends where the impedance and voltage are the highest.
prcguy
