Long-term integration to detect band activity?
HB9EVN
Hi everyone,
As I wasn't able to find anything on the topic, but think that this can't be my original idea and thus probably is implemented somewhere, I wanted to ask if anyone can give me a hint.
I'm looking for a software to work with any SDR (but ideally RTL-SDR devices) which can integrate signals over a long period of time, e.g. 24 hours. Like this, band activity should be easily detectable, and I should be able to iddentify active / busy channels. Is there anything anyone is aware of, which is doing this?
Basically goes in the same direction as the 24-hours-pictures on the Uni Twente web SDR server, but ideally reduced to a single dimension, ideally with adjustable thresholds (similar to squelch).
Any hints would are very much appreciated!
HB9EVN
For future reference: I have found a piece of software that seems to be doing exactly what I was looking for: RTLSDR Scanner.
thewraith2008
You could look at creating heatmap images. See link below for rtl_gopow for example.
This requires a little manual labor (using the command line) but is done using the RTL Driver package (rtl_power) and rtl_gopow.
In this RTL driver package is a program called rtl_power.exe
This will scan a range of frequencies and generate a CSV file for a defined period of time.
Code:
rtl_power -f 118M:137M:2k -i 10 -e 15m logfile.csv
NOTE: You would also use ppm and gain options, not shown for clarity.
More info here about rtl_power it. (use -h for command line help)
You then generate the heatmap image using rtl_gopow using the CSV from rtl_power.
Code:
gopow -i c:\rtl\logfile.csv -o c:\rtl\heatmap.png
There was a GUI program around called "RTL_POWER_Disp" to view heatmap with the ability to indicate frequency at mouse position.
I can't find link to it. (old one dead)
Hope this is useful.
thewraith2008
Here is another (and easier) alternative: GUI for rtl_power
Shows list of active frequencies + a waterfall heatmap (only partly shown in image at bottom)
ATCTech
This combination works extremely well, thanks for the posts!
