I just picked up a Grundig G6 radio. I'm completely new to SW Radio lisening. It has an 1/8th inch mini jack port for an external antenna on side. I soldered on 50 to 100ft of 20 ga stranded wire to the center pin of plug and plugged it in. I seem to get a lot of static on some bands and on other bands it work good compared to the Telescoping antenna on the radio. The wire is ran from the radio to a window, a small hole routes the wire outside and onto the top of roof. The wire is just laying on roof. There is a over the air TV antenna mounted on chimny of house. My questions are
1) Does the length of the long wire antenna matter to which frequency band you are trying to recieve?
2) Would it be better to attach the wire to the TV antenna?
3) should I run a shielded wire in the house and then splice the long wire to the center of the sheilded wire outside the house, and splice the shield to a ground in the house say the center screw on a power outlet? Would that cleanup my reception?
4) Run a shielded wire al the way to tv antenna, run center to antenna and shield to grnd? would that be better then a Long wire?
I know it is a lot of questions... thanks for input.
