As of this morning, Longmont PD CH 1 (VHF) is patched to TG9515. So far everything that I've heard has been in the clear.
I'll work on getting more info...
-Brian
-Brian
-Brian
Given the lack of the MDC1200 "chirps" on VHF and the different Radio ID's on DTRS, I would say the field units are in fact using DTRS.
Here are the radio ID ranges I am seeing for the PD units:
3544xx
3546xx
And dispatch comes up as either:
382801
382295
I'm only listening to the Sunset Tower...
-Brian
3544xx
3546xx
382801
382295
-Brian
Same from Lookout...
382951 appears to be a dispatch id also.
also seeing 3545xx field radio's.
Hope they test all their tg's today![]()
Longmont ID's and affilating on Lookout Mtn? That's great to news.
Good news for scanner listeners, bad news for system users that need to get a message through. It will just result in more busies.
What a waste of resources....
I just noticed an update in the DB with what I assume are all non-sensitive Longmont TG's. I'm guessing these came from someone "in the know" that doesn't want to be identified, understandable and thank you!
-Brian
The boatload of school buses that will load up the Lookout site in the coming weeks is way more taxing than a Longmont radio occasionally roaming on it.
That's exactly the problem. The lone one or two radios stuck on a busy site like Lookout with no or seldom open channels will delay traffic for the guys in Longmont because the zone controller is waiting for that lone radio to get a channel. It may only be a few seconds but it is a huge leap of a change for first responders used to an analog system. For critical situations found in LE, this few seconds of delay is a potential danger.
That's a great point on how the system works, somehow I wasn't connecting the dots that a voice channel has to be open on every tower that a radio is affiliated with for a particular TG grant to go through...
-Brian
Pretty good initial list will be interesting to see how accurate it is.
Jim<
skot1923 said:That's exactly the problem. The lone one or two radios stuck on a busy site like Lookout.......
dont the radios have an emergency button that can be pressed to give the operator of that radio priority if there is an emergency?
