Longwire Impedance Matcher
Saint
Fort Erie Ontario Canada
I am going to put out on my balcony 80' feet of speaker wire. I am going to make a large square with the wire and also connect the longwire to an LIM-Longwire Impedance Matcher. My question is when I finish making the square out of the Longwire do I connect both ends of the speaker to the LIM-Longwire Impendence Matcher.
Steve
Blackswan73
Central Indiana
If you connect only one side, then you will have basically a long wire that is a good wideband receive and somewhat ominidirectional antenna. If you connect both ends, then you have created a loop antenna that will be resonant on a very narrow range of frequencies, and very directional
Saint
Longwire antenna
Ok, thank you I was not aware of that.
Steve
Saint
Antenna
Better you hook it up as a long wire it will be more broad banded.......
Yea, I will hook it up as a broad Band, I will be using it for HF Utility listening and it's going to face North on my 4th floor apartment balcony, I had it up a couple of years ago and it work great but was wondering about the two different ways to hook up the wire.
Steve
