Looking at an NX210, have some questions.
dryfb
America
I'm considering buying an NX210 that has been retired from a railroad, are these usually password protected? If so, is there any way to bypass the password? Also, do these radios use special firmware like some Icoms?
kd4efm
Florida
It can be flashed with regular fw 5.32 for the nx-210.
As for password, depends on what RR used it.
kd4efm
Florida
Product is end of life, honestly I would save and get a nx 3000 or even 5000.
Good radios. Our PD has been using them as a temporary solution, which turned into 10 years….
They've stood up well to that sort of use.
They'll do 2 meter band if you have your ham license.
KPG-111 is fairly easy software to figure out if you have not programmed them before.
But I'd agree with Evans, if you have the money, the NX-3200's are nice radios.
dryfb
America
I don't think I could get a 3200 or 5200 because of the cps adding another 200 to the cost, I do have my ham license so that will be a primary use for this radio. I already have kpg143d which supports the 210. What are the prices on a 3200 and 5200? I already have a 1300k2 so a 1200k2 would be an option, I would like the better display on the 5200 along with the channel capacity and voice playback as well as dmr and nxdn at the same time.
kd4efm
Florida
The D1 or D3 key is 145 through me (plus paypal fee). Not really 200 but if you want to gag,
the wide band key is 175.00, which I stock also.
dryfb
America
145 isn't as bad, what's a normal price for a 5200 with the DMR key, and SD card size upgrade, along with bluetooth programming?
dryfb
America
Also, does the 5200 come in any colors other than black? I've seen a lime green 3200 on ebay and I'm not sure if it's custom or not.
Cognomen
Radioactive Zone
Yes, you can get green and red hi-vis housings for the NX-5200. The green was recently discontinued, but should still be in stock at dealers.
KWD-YH-3000U is the high viz yellow housing. Not sure if there is a lime green housing available now or not.
List price was $41 bucks in 2021. Standard keypad model only. Requires factory install if you want the warranty on the IP67 rating.
dryfb
America
I have decided and buy one with a speaker mic and no charger, and I'll also be buying a bluemax cable.
