It appears that you are attempting to condition/exercise batteries for a XTS1500/2500? The batteries are not in the correct position. The top of the batteries needs to point down and make sure that the brass contacts on the battery are making contact with the brass contacts points on the BMS Adapter. The doo-hickey that slides on the bottom of the battery should be top when the battery is properly connected to the BMS Adapter
What you are seeing happening on the display is the initial BMS start-up procedure and the display goes blank/times-out because it senses that there is no battery in contact with the BMS Adapter. If the battery was making contact with the BMS adapter, the display would indicate that the battery is being charged, which is the automatic/default function, and display that function constantly.
If the battery chemistry is Lithium you need to make sure that the BMS Adapters are Lithium compatible. It will say what is the compatible battery chemistry underneath the BMS Adapter.
After, you position the batteries on the adapter correctly, you press the "Condition" button to start the exercising/conditioning procedure of the battery. It will take approx. 1 hour per the remaining effective battery milli-amp hour capacity to go through the three exercising cycles. Thus, if the battery has a remaining capacity of 2000 Mah, then it will take approx. 20 hours to condition/exercise the battery. If the battery is being used in a public safety environment, and battery has less than 80% capacity, that battery should be disposed of, and 70% for a non-public safety activity.
If the batteries have not been exercised or used in a long period of time, you more than likely will get the "E01" error after the battery is discharged for a couple cycles. If that happens you will need to "Cycle Test" a.k.a. "Forming" the battery. The manual will explain on how to do that. Essentially, you are just waking the battery up after being lazy from not doing anything for a long period of time.
It turns on, lcd all light up and then go blank and none of the buttons seem to work. I have 2 and they both do the same thing.
Can't find a manual online, anyone got one or other insight?
