musiclistener
The signal is constant on 10.155 Mhz. No luck with sound bites of digital modes on the internet. Any help would be great. Thanks.
Post a screen shot if you're seeing it on a SDR. Record a video of it if it's a portable or a desktop radio or just record a 10 second clip of the signal then post it. That'll help people help you.The signal is constant on 10.155 Mhz. No luck with sound bites of digital modes on the internet. Any help would be great. Thanks.
10150 to 11175 kHz: This segment is used by fixed stations. In addition to various FSK and digital modes, you may hear several international broadcast stations being relayed in SSB. These "feeder" stations are used to send programming to relay sites not served by satellite downlinks.
That's N.A.T.O. or Military FSK which sort of sounds like RTTY. Maybe ARQ-E or N not sure. It's also encrypted. No way to decode it except maybe the headers which is quite boring. Sounds like 850bd which is very wide as compared to ham radio RTTY at 45bd which is decodable.I have added a sound bite of the digital sound that I am looking to decode
Might want to check again seems they changed recently.If you adjust 4007 to 4005 (the other 2 freqs are correct), you will find the sites (found by TDoA) identified on the wiki article I mentioned in message 3 of this thread...Mike
Done it but I fully understand someone else may edit it back. If they do they really should check 4005 did switch to 4007.If you know which ones changed - certainly possible - feel free to go into it and make the corrections
Mike
