Looking for an antenna?
trlydon88
Keene, New Hampshire
Hi All!
Im going to be getting my first Ham Radio for reception reasons. I will not be transmitting, just getting to receive a frequency. I need an antenna with a range of 25 miles. The radio has a SO-239 Connector, and im looking at one base antenna at the time, but im worried I will exceed 25 miles. If I exceed 25 miles, I will start to pick up Brattleboro VT Base. Any recommendations? Thanks!
Radio: 2016 VV-898E *Plus* Backpackable Portable Dual Band Car Mobile Radio VHF/UHF 25W | eBay
jonwienke
PA
That is a strange criteria for antenna. And probably wrong. You get the best antenna you can afford that will give you the best reception (and eventually transmission) possible given the terrain, possible mounting height, etc. If you don't want to receive a particular station, you get a RADIO with good selectivity--the ability to filter out stations on frequencies other than the one you wish to hear.
Specifying a range for a particular antenna while it is sitting in the box is impossible--there are too many variables. Maximum communication range between two radios depends on many variables, most importantly the transmit power and receiver selectivity of each radio, each antenna's design, tuning, height above ground level, the length and type of coax used, atmospheric conditions, and the terrain between the antennas.
Going from mountaintop to mountaintop with a clear line of sight, it is possible to go 25 miles with a pair of walkie-talkies with "rubber duck" antennas running less than 1 watt of TX power. But in an urban setting with lots of tall buildings, maximum range may be less than a mile between vehicles with mounted antennas and 50-watt radios.
Before anyone can recommend anything meaningful to you, you'll need to give more info about what you're doing and where you're doing it. If you aren't transmitting, there's no reason to buy the radio in your link; you could accomplish pretty much the same thing with a Baofeng UV-5R at a small fraction of the cost and weight.
trlydon88
Okay, I am going to be monitoring our local bus company. Im in Keene, NH. If I get too much reception, I will pick up Brattleboro VT Base. But, we have drivers on the NH/VT border that needs to be picked up... I'm looking at this current antenna, but am worried it will pick up too much reception. (Pick up Brattleboro Base.) VHF 144-174 MHz BASE STATION ANTENNA | eBay
The radio will stay in the house at all times for monitoring purposes. I hope this info helped.
I like the idea of a handheld, but would prefer a base station.
teufler
ST PETERS, MISSOURI
if the bus groups you monitor run a sub tone, no problem. One tone will blot out the other. This would solve the problem. If all you are doing is to receive, use a scanner attenuator, this will effectively reduce you signal receive range. Th antenna you showed a picture of looks good, though to reduce you range, a simple quarter wave, 18" spike would let you receive. Since you are just receiving, try an indoor antenna, or keep you antenna lower than optimum. You could go with the antenna you sent a picture of mount it lower .VHF i sort of linme of site. Keeping th antenna lower will effectively reduce your receive range also.
trlydon88
Okay, thank you very much! this helps a lot!
kmi8dy
ARIZONA and MICHIGAN
forget the radio in your link. you don't need a transiever to do what you say your going to do. buy a uniden bc355n for about half the money or so. $ 90.00 put in the frequency you want to hear, sit back and listen. most if not all antennas are made to pull in any and all transmissions it " hears ". what is the frequency you want to hear ?
trlydon88
Frequency is First Student, 155.295.
jonwienke
PA
Is Brattleboro running on the exact same frequency and PL/CTCSS tone?
trlydon88
I know they have the same frequency (155.295) but unsure on PL/CTCSS tone.. Im assuming so, because every once and a great while our dispatcher will ask Brattleboro Base to relay for her. (Ex: Swanzey Base to Brattleboro Base can you relay for my bus 7 please?)
jonwienke
PA
Find out about the tone. If you're talking about separate dispatch centers, it's probably different. The drivers need a way to hear only their dispatcher...
Failing that, you can always adjust your squelch so that you hear only the nearer dispatch center.
But don't deliberately buy a sub-par antenna to limit your range. You may find yourself needing to hear the other dispatch center someday.
