Looking for an HT with specific featurs
pico1180
This seems to me like a really noob question, but I'm pulling my hair out here. Every time I think I'm getting close t finding what I want, I realize it isn't. Every time I DO find a radio that can do everything I want, I'm looking at a $5k Motorola and that is NOT what I want.
I am looking for an HT that with the following features.
Mandatory:
136 - 174, AND 400 - 520 freqs
MIL-STD or IP54 for rain, humidity, dust and shock
CTCSS Encoding/Decoding
Has at least 3 memory banks that can be toggled between with a physical switch/knob
Doesn't require specialized training to program
Desirable:
P25
5 or more memory banks
$300 or less price point
Keep dreaming, because we all do? Or keep looking, its their, you just haven't found it yet?
pinballwiz86
Missouri
It's not out there. Best bet is to get a used P25 radio and have someone program it for you.
pico1180
kenwood comes pretty close, but they either do VHF or UHF, but not both.
I can do with out the P25. But the multi zones with VHF AND UHF is really the big thing.
kayn1n32008
ØÆSØ
Sector 001
Mandatory:
Desirable:
P25
Currently the only companies that produce a multi-band portable radio with the features you desire are Motorola and Harris. Neither of which you will get for $300. You may be able to get a APX-7000 in VHF/UHF-1, but you will spend upwards of $2500 to get it.
krokus
Southeastern Michigan
Mandatory:
Desirable:
P25
Are you wanting to transmit on those freq ranges, or listen to those, with transmitting on ham freqs?
Good luck on that price point.
Sent via Tapatalk
Priority-One
Anonymous participant
Banned
Bronx, NY
why not just get a BCD396xt? they run around $300 now. ive seen them for $275. that's if you don't have the need to Tx.
jaspence
Michigan
The 400-520 spec is not available in anything but the cheap Chinese radios. The better radios break that into two sections,
pico1180
I would need to transmit in the 136-174 range, I would need to transmit in the (specifically) 407-416 range, and I would need to transmit in the 462-467 range.
I am a lineman for the county.
P25 is going to be the killer for you.
If you remove that from your list of requirements, it opens up the plethora of cheap Chinese radios, although I'm not sure I'd trust any of their claims about IP54, and finding the A/B/C zone switch isn't going to happen etc.
The reason you keep coming up with $5000 Motorola's in your search is because that is how much a quality radio with all these features cost. You will not find a new radio with all these features for $300. Your budget is not realistic based on your requirements.
Used, and APX series radio might be down closer to $2000, but "Doesn't require specialized training to program" isn't going to apply here. While "specialized training" isn't required for all of them, these are not hobby/amateur grade radios. The number of features and options make them complicated. The interaction of the features make it not something easy for a newcomer to tackle.
So, you either need to change your requirements or change your budget. As it stands right now, yours are not realistic.
This frequency range raises some questions.
You don't show in your profile where you are located, so its hard to figure out exactly why you need to transmit on this much spectrum.
Here in the USA, a lot of that spectrum is for federal government use. If you are an employee of the federal government, then your agency should be issuing you a radio.
I'd also be curious exactly what licenses you have that give you authorization to transmit in these frequencies.
The ranges you are looking for are not exactly compatible with any "normal" FCC license. Like I said above, some of these frequency ranges are federal, and that means NTIA level stuff.
462-467 suggests you are looking at GMRS, and that would require Part 95 certified radio in addition to your listed requirements.
Maybe if you can clarify -exactly- what YOU are licensed for and what you exact usage is, we can make some suitable suggestions for a solution. Looking at your requirements suggests a hobbyist looking for a cheap solution to a very complex problem. Happy to assist in any way I can, but more accurate information is needed.
pico1180
I knew this would come up sooner or later....
Suffice to say, situation dictating, I can transmit on whatever frequencies I have a need to.
The 136-174 is CDF/CalFire. The 407-416 are my agencies frequencies. And you nailed it with the GMRS.
The amount of radios that we use is mind boggling, and disappointing to be honest.
Our disaster preparedness section has GMRS setups for "community outreach".
Our Hazardous Incident Respond Team uses a mix of business band which i don't know about, and GMRS radios.
In our section we have a Motorola contract that address our 407-416 needs and NOTHING more. Anything out side of that is outside the scope of the contract. There is a small chance I could push for a contract ratification, but the odds of that would be long.
If I present a $5000 radio for purchase, they would look at me like I had ***** on my face. Not to mention, I wouldn't need one, but more like 3 to 5. If I came to them with a "modestly priced" radio with promises of infrequence unification, I would get a lot further.
But lets be real. This is the government we are talking about. It is much easier to take the three radios they give me and be happy then to try and change the system.
buddrousa
Ok you said the magic word HAZMAT ALL RADIOS USED IN HAZMAT SHALL BE INTRINSICALLY SAFE using anything else in that environment you are risking you and your teams life with a chance of public loss of life. I have been in training class with Federal Response Teams and this topic is always at the top.
jonwienke
More Info Coming Soon!
VA
None of that applies if you simply need to talk to the hazmat people, as opposed to being a member of their team.
jonwienke
VA
There are several HTs that would meet most of your requirements within your price range, if you're willing to give up on a physical bank switch. What you're absolutely NOT going to get under any circumstances is P25 capability in that price range.
The Baofeng GT-3WP covers the frequency range you need, but does not have a physical bank switch or P25. But it's reasonably waterproof (I've taken mine kayaking) and under $50.
https://www.amazon.com/gp/product/B01CZU6402/
$203.04 for 5 radios and a programming cable.
