Looking for cheap CTCSS scanner to improve feed. Suggestions?
gmasem
Long Island, NY
Short version - I am looking for the cheapest scanner that does CTCSS to improve a feed. Used is fine, price being the most important factor. Any suggestions? Something I can find cheap on ebay would be great!
Long version with explanation....
I have a feed set up and finally running smoothly but came across a slight issue I would like to correct. At least one of the departments we are feeding dispatch on a couple different frequencies. The only solution I have come up with is to use a scanner with CTCSS to feed. Initially I was using RTL-SDR but had issues. Now I am using an old scanner I had here and getting the main channels without issue. However if I add different dispatch channels I am going to get a LOT of unwanted traffic.
I looked at one of the Baofeng radios and while I have few enough channels that the slow scanning would not be an issue, their implementation of CTCSS makes it useless. It doesn't make it skip channels just mutes audio...Unless I am misconfigured? As a workaround I can space the channels out so it scans the dispatch ones every 30 seconds or so, but I will still potentially miss some desired traffic. So that leads me to looking for a different scanner to feed from. I have searched and searched but not finding what I am looking for. Know of anything pretty inexpensive that does CTCSS?
jonwienke
More Info Coming Soon!
VA
Any current Uniden scanner will decode CTCSS and DCS. The cheapest model that will work for you depends on whether you need 800MHz coverage.
