Re: Whoops
LordJ said:
Ya, seem to have a gl problem. It is there without a gli and goes away when I put the one I have inline. But, as I stated in the first post, the gli I have cuts the audio by what seems like 50%. So I am looking for some better solution.
Is it hum?
If it is Hum and it is real bad you probably have a bad power supply. Get that fixed before you destroy something or worse.
Is it desense?
You sure it is GL, and not DC bias?
You should be able to use a 1:1 audio transformer, but a matching transformer is even better if you know (or give) the impeadances of what you are hooking together.
If it is a DC problem, you can block it with a capacitor.
If it is not to bad and you have signal to spare, a "H" pad will give you some isolation on both hot and ground sides.
(edit)
I have been assuming it is an audio problem, but since you have not siad, it could be data or RF connections also. They have different cures.
