Looking For Good Outlet Tap With USB Ports
JASII
Memory Capacity
I have noticed that more devices are available that have USB charging ports built into them. I have seen some that replace the in wall device and have two grounded outlets and a USB port or two. I have also seen others that plug in to a two outlet device expanding it and adding USB ports. Anyway, I would like to find one similar to this Walmart.com: GE 6-Outlet Grounded In-Wall Tap with Resettable Circuit Breaker, White: Computers where it has outlets at three different angles AND has USB ports built in. Has anybody seen any like that yet and, if so, where can I buy some? The reason I like the different angles is it seems easier to use wall warts. In fact, an older one I have, that doesn't have USB ports, has each set of two AC outlets in opposing directions, which is better, still, for wall warts. Anyway, what have you guys and gals seen that isn't outrageously priced?
