N4KVE
I used to live in Miami Florida, but moved 60 miles north to Palm Beach. While I use the local repeaters here, I still try to keep in touch with a few friends in Miami using the repeater down south. I use a 100 watt amp, had a preamp installed in my radio, but I just need a little more umph. I basically use UHF, but I have been using a Diamond 770NMO, & a 7200, as well as a Larson dual bander. The Diamonds claim 5.5 db, & the Larsom 3.5 db, but they all sound the same. If I'm 10 miles south in Lake Worth, the repeaters all come in great. So is there an antenna even if just UHF, about 40" that will work better than the antennas I am using? I'm using a trunk lip mount ant base with only 4' of RG-58 cable because the radio sits in the trunk, with the control head up front. 4 or 5 different radios give the same results. Any suggestions? GARY N4KVE
