I ordered the BC436HP.
Will putting in my zip code pick up anything around me in the database? Surely it isn't that easy?
You need to install Sentinel on your PC, then update the database in Sentinel. Once you receive the scanner, use Sentinel to update it as well. When shipped, the database in the scanner will be seriously out of date, as much as a year, or more. Getting the most recent update in Sentinel, then writing it to the scanner, will ensure that you have the most current information for your area. You can install Sentinel & get started before your scanner arrives.
Note that when the scanner is shipped, as well as when Sentinel is installed for the first time, only the Dispatch service types are active for Public Safety: Law Dispatch, Fire Dispatch, EMS Dispatch, and Multi-Dispatch. You should also enable the
Tac and
Talk service types, such as Law Talk, Law Tac, Fire Talk, Fire Tac, etc. If you plan, initially, to scan using the database, be sure that you update your location in Sentinel, so that is downloaded to the scanner when you update it's database. For more information on how Location Based Scanning works, see this:
How it Works: Location, Location, Location
Take a look at this Wiki page, as well as the links on it:
wiki.radioreference.com
(That's page 1; there is a page 2 as well in the Wiki.)
This page from Uniden has a link to install Sentinel, as well as the serial driver in case you later want to use ProScan or ARC536 for logging and control of your scanner via your PC.
info.uniden.com
There are online, Easier to Read manuals for
Sentinel, as well as for your
scanner.
