Looking for help with Etrunker 3.8.3 and com port problems.
I am looking for some thoughts on Etrunker 3.8.3 and why the program would just stop and display the message "want cts" on the top line. I know what it means ... the program has lost the control channel. But this doesnt appear to be the case.
The problem is as below.
This is after the program has run for a few hours or days and the control channel hasn't changed and the program is still running. (It still responds to key presses etc .... )
I can run the same exact exe on a 486 laptop for as long as I want .. it will never die. But running on a faster pentium laptop it is showing this problem.
I have slowed the processor down in the bios. - No help
Tried different laptops ... same problem.
If the program is started again ... it is fine.
Anyone have any thoughts ... or know of a good program I can use to help diagnose the problem ?
Any help appreciated .. as 486 laptops are somewhat hard to find.
Hi Kevin,
There is very likely some sort of race condition in the interrupt service routine used by ETrunk (in plain english - it's a bug). It's the same code as MTrunker but the interrupt rate produced by a 9600 baud EDACS control channel is higher so you're more likely to see the problem here.
Your best bet is to either use one of the newer programs (maybe r00t will create a Win32 version of ETrunk) or use older (and slower) hardware.
-rick
Thanks for your reply.
I found a little utility that essentially makes the cpu run at the speed of a 486. I will be testing it out .. and hopefully it works.
I have found an application called "COMTRAP" that seems to have resolved this issue. So far there have been no issues.
Its a DOS app and is run before etrunker is started ... :)
Thanks Kevin ... for those interested, here's the code and description of what COMTRAP is and how it works (neat stuff!) ...
; COMTRAP 1.0 - A TSR to trap unexpected hardware interrupts
; This TSR solves a problem that only occurs when using you wish to
; popup a swapping TSR over a communications program. Even then, the
; problem it solves occurs rather infrequently. The problem is that the
; swapping TSR will restore the vector table to what it was when the TSR
; was first installed (which temporarily removes the communications
; program's vectors). Unfortunately, the UART and PIC are still configured
; to process serial port interrupts, the old serial port vector gets called.
; Usually, this will be the BIOS's ISR to handle unexpected interrupts. This
; BIOS ISR will clear the interrupt but then mask further interrupts from
; that particular IRQ. When the swapping TSR is finally popped down
; interrupts remain masked off for the serial port IRQ; so, the communications
; program won't receive any more interrupts -- meaning no more serial I/O
; will take place and, in some cases, the communications program will
; appear to be hung.
; This TSR avoids the problem by installing its own serial port ISR so that
; when the swapping TSR replaces the vector table the serial port vectors
; will point to COMTRAP's ISR rather than the BIOS ISR. COMTRAP's ISR will
; clear any received interrupts but leave the IRQ unmasked.
; Note that versions of Object Professional 1.13 and beyond avoid this problem
; by saving and restoring the PIC state (the chip that controls which
; hardware interrupts are currently masked on or off). So, you'll only need
; COMTRAP if using earlier versions of Object Professional or with other
; TSRs or TSR libraries that don't save and restore the PIC.
; Note that it is still possible for a TSR (swapping or otherwise) to
; disrupt a communications program even if you are using COMTRAP. If the
; communications program using interrupt-driven transmits (as does Async
; Professional) and the TSR prevents the communications program from getting
; a transmit completion interrupt then the communications program will
; likely not be able to recover from this. You can protect your
; communications programs from this situation by installing a clock
; ISR that periodically checks for lost transmit interrupts and calls
; StartTransmitter when this occurs.
; To use COMTRAP, simply type
; COMTRAP x x
; where x is either 1 or 2 (for COM1 or COM2)
; Examples:
; COMTRAP 1 2
; traps both COM1 and COM2
; COMTRAP 1
; traps COM1 only
; If you wish to modify COMTRAP.ASM, use the following steps to rebuild it:
; TASM comtrap
; TLINK /t comtrap (use /t to generate a .COM executable)
; 1/8/92
; Terry Hughes
; released to the public domain
.model small
.code
ORG 80H
CmdLen LABEL BYTE ;command line length
ORG 81H
CmdLin LABEL BYTE ;first character of command line
ORG 100h ;this is a COM file
Initialize:
JMP NonResCode ;jump to start up code
NullComHandler:
PUSH AX
INC CS:BadCnt
MOV AL,020h ;non specific EOI
OUT 020h,AL ;issue the EOI
POP AX
IRET
GoRes:
CMP CS:GotArg,0
JE ErrMsg
MOV AX,CS
MOV ES,AX
MOV DX,OFFSET NonResCode
ADD DX,15 ;force round up
MOV CL,4 ;for div 16
SHR DX,CL ;convert bytes to paragraphs
MOV AX,3100h ;terminate and stay resident
INT 21h
Flag DB 'BadCnt:'
BadCnt DW 0
NonResCode:
CLI
MOV SP,0FFh ;use command of PSP as temp stack
STI
MOV AH,09h ;show title
MOV DX,OFFSET TitleMsg
INT 21h
MOV SI,OFFSET CmdLin ;point to command line
CLD
Get1: LODSB ;get first non-blank
CMP AL,32 ;skip space
JE Get1 ;
CMP AL,9 ;skip tab
JE Get1 ;
CMP AL,13 ;finished if no more input
JE GoRes ;
CMP AL,'1' ;
JL ErrMsg ;error if less than '1'
CMP AL,'2' ;
JG ErrMsg ;error if greater than '2'
CMP AL,'1' ;
JNE InstallCom2 ;
MOV DX,OFFSET NullComHandler ;install handler for com1
MOV AX,250Ch
INT 21h
INC CS:GotArg
JMP Get1
InstallCom2:
MOV DX,OFFSET NullComHandler ;install handler for com2
MOV AX,250Bh
INT 21h
INC CS:GotArg
JMP Get1
ErrMsg:
MOV DX,OFFSET UsageMsg
INT 21h
MOV AX,4C01H
INT 21H
TitleMsg:
DB 'COMTRAP 1.0', 0Dh, 0Ah
DB 'released to the public domain', 0Dh, 0Ah, '$'
UsageMsg:
DB 0Dh, 0Ah, 'Usage: COMTRAP x x', 0Dh, 0Ah
DB ' where x x are the numbers of the COM port to trap [1..2]', 0Dh, 0Ah
DB ' example: COMTRAP 1 2 will trap invalid interrupts to COM1 and COM2', 0Ah, 0Dh, '$'
GotArg DB 0
_TEXT ENDS
END Initialize
Thanks Rick for this ..
As far as Etrunker .. I have been running it with the COMTRAP and have has no problems anymore. :)
Lets say that it is awesome as I have had issues with some laptops having problems. Now it appears that there are no more issues .. and Etrunker is running great.
I couldn't be happier ...
To anyone that has had the problem described above, try this out.
Cool. I'm thinking this could be adapted directly into ETrunk and Trunker. I had never considered the possibility of a TSR causing this.
-rick
I dont know if you misunderstood my last post, or maybe I misread your response. :?
It is Comtrap that RESOLVED the problem I was having. I was finding that one laptop I was using would last from 3 hours to about 3 days before dying. It is now running fine 24/7.
Understood ... and the COMTRAP source code offers some insight on how to change the ETrunk program so that COMTRAP isn't needed.
-rick
Just a little tidbit ... the laptop died again, but I think that it may have helped delay things. I dont understand assembly .. so I can't be of any help on this.
