looking for interesting frequencies
lucky43113
Central Ohio/Pickaway County
im in pickaway county and have a lot of stuff programmed in my new bcd996p2 all the local stuff plus columbus airport railroads rickenbacker airbase etc.. anyone have any interesting freqs i could try.
Also am I too far away to pick up wright pattersron AFB in dayton?(i am roughly 80miles east of wpafb) i have a jtd1 discone antenna about 20ft in the air
radioscan
Radio Sensei
Butler County, Ohio
You won't receive the WPAFB trunked system from that distance, but you should hear some of the inbound and outbound aircraft.
Program these in for refueling operations: Military Scanner Frequencies and Radio Frequency Reference
Also program the Cleveland and Indianapolis ARTCC frequencies local to you.
lucky43113
radioscan
Radio Sensei
Butler County, Ohio
Also program in the frequencies used by the 180th Fighter Wing (FW) out of Toledo.
They make regular use of both Brush Creek and Buckeye MOAs for Air Combat Maneuvers (ACM).
TailGator911
Fairborn, OH
WPAFB Base Ops
Does WPAFB use the 400mhz trunking system for base operations? I live about 1 mile from the gate (in Fairborn) and my wife is a supervisor at the base hospital and I would like to monitor hospital security while she is at work. A couple of years ago I was told this was not possible as all base ground communications were encrypted. Then this last summer when we were camping and fishing at the lake on base I briefly spoke with a security officer (one of their field offices is right there at the RV campground) who told me he has scanners at his house that he uses on his down time to monitor his post. Before I could nail him down for any hard facts he had to leave on a call. He told me they still used 2 conventional frequencies but only on weekends (?) Does anyone know if this is true or not?? I have been wondering ever since if I am actually able to scan the base.
Any updated info about the base ops would be greatly appreciated -
thanks 73's
lucky43113
thanks 73's
Wright-Patterson Air Force Base Trunking System, Riverside, Ohio - Scanner Frequencies
Base Security is now using encryption on a random basis.
W8RMH
Feed Provider Since 2012
I go to Wright-Pat quite often and monitor when in the area. Base Security/Police, Fire/EMS, and hospital security is 100 percent encrypted.
TailGator911
Fairborn, OH
What TGs, specifically, are you hearing, N8JJ? I get a TG not listed in RR, 1084, and it is not encrypted, either. A good security channel. Some of the others are on again off again, clear voice, then Donald Duck.
N8JJ
Beavercreek, OH
57021. 57022 are security
Make sure you are using system 157, which is the US Air Force system on 400 Mhz
