Looking for programing software for Weicom 3288S
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
It also goes by the name VEV-3288S. This is what it looks like although I have a different model in the frequency band. 1x WEIERWEI VEV 3288S 136 174Mhz VHF Radio VEV3288SV | eBay
Their website has the software, but it's in Chinese and I seen a YouTube video recommend the Puxing 6in1 software. When I try to read from the radio it seems to connect and it won't read. I'm using a PL2303 USB adapter. Looks like this: USB Programming Cable for WEIERWEI VEV 3288S 6288 3288 VEV 5288 5299 VEV 6299 | eBay
Not sure if it's the software, computer or adapter. I used this adapter successfully before on this laptop with a Kenwoood TK373G.
KC9HI
I would double check the driver that the programming cable is using. Most low cost programming cables are made with an unauthorized (aka conterfeit) copy of the Prolific USB-to-Serial chip. The driver that is automatically installed by Windows Vista, 7 & 8 is the very latest driver from Prolific. This driver has been purposely been made to detect and then fail with these unauthorized chips. The only way to make these programming cables work is to downgrade to a driver that doesn't have this detection.
V2.0.2.1: Windows XP
V3.2.0.0: Windows Vista, 7, 8
Here is a source for the driver and a guide for installing it.
Prolific Windows Cable Drivers
Jim KC9HI
cabletech
Puget Sound
Man, I hate sub amateur people trying to play professional with radio equipment.
No wonder radio systems are so badly messed up.
"poltergeist" Not sure if it's the software, computer or adapter. I used this adapter successfully before on this laptop with a Kenwood TK373G.
What 'adapter' are you referring too? The cable you linked to? If that is what you used on the Kenwood, then it WILL not work on the Weicom 3288S.
Two different radios with different wiring setups.
Your software is in Chinese because it was made for the Chinese.
Remember, buy cheap, get cheap.
You have to use the correct cables and software for the device you are trying to work with.
poltergeisty
Banned
